Старый 22.06.2011, 15:11   #1
Leon's CRM Musings: A Slightly More Elegant Codeless Universal Search For Dynamics CRM
Источник: http://leontribe.blogspot.com/2011/0...-codeless.html
This is a follow-up to the Codeless Universal Search post I did a week or so ago (http://leontribe.blogspot.com/2011/0...-dynamics.html). Fellow Dynamics CRM MVP George Doubinski suggested using a custom activity entity and make use of the activity ‘Regarding’ field which can link to any normal record. The advantage being we no longer need one column per search entity in the results. The good news is it works.
What Does It Look Like?
How Does It Work?
To this entity we add 1:N relationships to the entities we want to search on and a keywords field, as before, to populate with the things we want to search on.
The workflows work the same as before, except we populate the regarding field on the new entity record.
The final step, as before, is adding the keywords field to the find Fields of the Quick Search.
This should work for any entity we can associate activities to.
Making It A Standalone Search Box
Something you can also do to either the original version or this one is make it a shortcut outside of CRM which you can have as a favourite in Internet Explorer or a shortcut on your desktop.
To do this, firstly browse to the default view for the new entity.
You will see at the top you can ‘Copy a Link’. If you select the little black triangle next to this, it lets you copy a web link to this view. I was getting an error when I tried this online so if it fails use the ‘E-mail a Link’ instead and copy just the web address part. Open up a blank web page, copy in the link to see if it works and if it does add it to your favourites.
Enjoy.
Leon's CRM Musings: A Codeless Universal Search For Dynamics CRM Blog bot Dynamics CRM: Blogs 0 08.06.2011 15:11
Leon's CRM Musings: The ‘Fun’ Salesforce Becomes the FUD Salesforce Blog bot Dynamics CRM: Blogs 0 29.01.2011 21:11
Leon's CRM Musings: Dynamics CRM Resources for the Rest Of Us Blog bot Dynamics CRM: Blogs 0 06.11.2010 03:11
Leon's CRM Musings: Book Review: Teach Yourself Microsoft Dynamics CRM 4 in 24 Hours Blog bot Dynamics CRM: Blogs 0 21.07.2010 09:06
Часовой пояс GMT +3, время: 02:03.
