Старый 21.10.2010, 16:08   #1
Why not? is offline
Why not?
? Проблема заведения новых пользователей
Добрый день.
Никто не сталкивался с такой проблемой, CRM 4.0 Rollup 10, завели нового пользователя, выдали права. При заходе пользователя в CRM вылетает ошибка, что недостаточно прав, в логах вот такое сообщение:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 21.10.2010 16:40:00
Event time (UTC): 21.10.2010 12:40:00
Event ID: f03e22cb306948b0b24b6a016a05c535
Event sequence: 305247
Event occurrence: 90
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT-1-129320488475882203
Trust level: Full
Application Virtual Path: /
Application Path: C:\inetpub\wwwroot\
Machine name: SMSK01CRM01
Process information:
Process ID: 2000
Process name: w3wp.exe
Account name: cmpname\crm
Exception information:
Exception type: TargetInvocationException
Exception message: Exception has been thrown by the target of an invocation.
Request information:
Request URL: https://crm4.bacint.ru:443/bac/default.aspx
Request path: /bac/default.aspx
User host address: 10.101.198.201
User: cmpname\Anton.Ivanov
Is authenticated: True
Authentication Type: Negotiate
Thread account name: cmpname\crm
Thread information:
Thread ID: 3
Thread account name: BACINT\crm
Is impersonating: False
Stack trace: at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Web.Services.Protocols.LogicalMethodInfo.Invoke(Object target, Object[] values)
at Microsoft.Crm.Extensibility.InternalOperationPlugin.Execute(IPluginExecutionContext context)
at Microsoft.Crm.Extensibility.PluginStep.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.Pipeline.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.MessageProcessor.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.InternalMessageDispatcher.Execute(PipelineExecutionContext context)
at Microsoft.Crm.Extensibility.ExternalMessageDispatcher.Execute(String messageName, Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, PropertyBag fields, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.RequestBase.Process(Int32 primaryObjectTypeCode, Int32 secondaryObjectTypeCode, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.RequestBase.Process(CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.CrmServiceInternal.Execute(RequestBase request, CorrelationToken correlationToken, CallerOriginToken originToken, UserAuth userAuth, Guid callerId)
at Microsoft.Crm.Sdk.InProcessCrmService.Execute(Object request)
at Microsoft.Crm.Application.Platform.ServiceCommands.PlatformCommand.ExecuteInternal()
at Microsoft.Crm.Application.Platform.ServiceCommands.UpdateCommand.Execute()
at Microsoft.Crm.Application.Controls.AppPage.UpdateUserLanguageIfNecessary()
at Microsoft.Crm.Application.Controls.AppPage.OnInit(EventArgs e)
at System.Web.UI.Control.InitRecursive(Control namingContainer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Все пользователи, которые были заведены до этого нормально заходят в CRM, хотя иногда подобные ошибки для них появляются в логах. При этом с такими же правами другие пользователи также бес проблем заходят.
Заранее спасибо!
Custom event details:
Маппинг пользователей при импорте организации migunov Dynamics CRM: Администрирование 2 25.06.2009 12:19
Проблема с заведением пользователей Camena Dynamics CRM: Администрирование 11 30.04.2009 14:38
Проблема при создании мероприятия ShurikEv Dynamics CRM: Функционал 2 03.11.2008 18:26
Добавление пользователей в CRM4 AlexsSDa Dynamics CRM: Администрирование 22 14.07.2008 11:21
Проблема с добавлением пользователей xm-ad Dynamics CRM: Администрирование 5 26.10.2007 15:58
Часовой пояс GMT +3, время: 12:21.
