Dianne Siebold: Generate a Report of Reports
Источник: http://blogs.msdn.com/b/dsiebold/arc...f-reports.aspx
============== If you have ever thought to yourself, "Gee, I sure wish I had a list of all the reports in my AX installation," then your wait is over. Now you can use this handy report to generate a list all of the reports in your AX 2009 installation. After you import the XPO, you'll see a project called BookOfReportsV1. Within this project there's a report called BookOfReports and an output menu item called BookOfReports. To run the report, just right-click on the report and select Open. ![]() Many thanks to Jose Lorenzo at Microsoft for providing this code. Источник: http://blogs.msdn.com/b/dsiebold/arc...f-reports.aspx
