Старый 04.06.2010, 21:06   #1
paruvella: Workflow approval pending records from Ax User Login
Источник: http://paruvella.spaces.live.com/Blo...4DB0!534.entry
The following example gives an idea about how we can see the Workflow approval pending records, from a particular user Login.
In this example, I want to know, which all the ProjProposal Invoice records are pending for workflow approval process from my login Id.
static void WFApprRecordsFromUser(Args _args)
  qbds, qbds1;
  qbr;
  query = new Query();
  qr;
  projProposalJour;
 qbds = query.addDataSource(tablenum(ProjProposalJour));
 qbds.clearRanges();
 qbds.clearLinks();
 qbds1 = qbds.addDataSource(tablenum(WorkflowWorkItemTable));
 qbds1.addLink(fieldnum(ProjProposalJour, RecId), fieldnum(WorkflowWorkItemTable, RefRecId));
 qbds1.addRange(fieldnum(WorkflowWorkItemTable, RefTableId)).value(QueryValue(tablenum(ProjProposalJour)));
 qbds1.addRange(fieldnum(WorkflowWorkItemTable, Status)).value(QueryValue(WorkflowWorkItemStatus::Pending));
 qbds1.addRange(fieldnum(WorkflowWorkItemTable, UserId)).value("santo");
 qbds1.joinMode(joinmode::ExistsJoin);
 qr = new QueryRun(query);
 while (qr.next())
 projProposalJour = qr.getNo(1);
 print projProposalJour.RecId;
 pause;
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Leon's CRM Musings: Auto-assigning workflow-created records to the current user Blog bot Dynamics CRM: Blogs 0 05.02.2010 15:05
Kashperuk Ivan: Run AX as a different user from Windows Explorer Blog bot DAX Blogs 0 15.01.2010 02:09
C# and AX Development: AX user cannot make login Blog bot DAX Blogs 1 26.07.2008 11:47
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 10:06.
