If you are testing out NAV Web services and find that you cannot make any calls beyond your initial and then find that the NST is no longer running, please try the following:
Compile the following: Type ID Name CU 6810 EP Request Handler CU 8700 Mobile Document Dispatcher CU 99008528 BizTalk Appln. Srv. Startup The error commonly occurs because one or more of these three codeunits do not have an entry in table 2000000071 - Object Metadata. They are all called in codeunit 1 on CompanyClose(). This then means that the call itself will run fine, but the closing of the connection will cause the failure and the NST to crash. Lars Thomsen Support Engineer Microsoft Support Источник: http://feedproxy.google.com/~r/Micro...vice-call.aspx
