kamalblogs: Vertical Selection in X++ Editor in Dynamics Ax
Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
============== Generally in use X++ editor we use line selection or complete block selection to modify the text. In Ax you can also use vertical block selection to remove spaces or delete text. Here is a small demonstration of vertical block selection along with the way to do it. ![]() Источник: http://kamalblogs.wordpress.com/2010...n-dynamics-ax/
| За это сообщение автора поблагодарили: casperkamal (1). | |
"Жмем Alt-O и выделяем вертикальный блок" - где ж ты раньше был?!
Оказывается, эта возможность даже в 3-ке есть...
Hi Gloomie,
Thanks for the comment. But was not able to understand your comment through translators w..can you translate so that i can answer it ? |
А я знал
![]() На самом деле не так часто эта возможность и восстребована
Модератор
Axapta
For casperkamal: I wrote that this Alt+O combination is mentioned in the Inside Microsoft Dynamics AX 2009 book on the 70th page. But in the Inside Microsoft Dynamics 4.0 book it is written that this combination is Ctrl+O. Цитата:
It seems it is working even in DAX 3.0."
| За это сообщение автора поблагодарили: Gustav (2). | |
Just to clarify, for casperkamal's sake:
There is always a lot of sarcasm on this forum, whenever a "well-known" AX feature is "re-discovered". Just so that you read the comments in the correct context. We are in general very nice people
Не забываем назад переключится Shift - O
![]() @Kashperuk Thanks Kashperuk. Very well understood. I just made it a trial post to see how posts with video works.. moreover lot of programmers i have interacted haven't picked it up (Alt + O)...so just thought would do that.... will help beginners
Последний раз редактировалось casperkamal; 07.05.2010 в 12:11. |
| За это сообщение автора поблагодарили: Lemming (5), alex55 (1). | |
#9 |
