CRM Programmer: Update a number of custom attributes of DynamicEntity with TargetUpdateDynamic.
Источник: http://crmpro.blogspot.com/2009/10/u...erties-of.html
============== This code I was used in plugins for updating the custom attributes using Microsoft.Crm.SDK. using System; using System.Collections.Generic; using System.Collections; // Microsoft Dynamics CRM namespaces using Microsoft.Crm.Sdk; using Microsoft.Crm.Sdk.Query; using Microsoft.Crm.SdkTypeProxy; ... // Extract the DynamicEntity from the request. entity = (DynamicEntity)retrieved.BusinessEntity; // declare a property array ArrayList arrProps = new ArrayList(); // create some property CrmBooleanProperty new_withindustry = new CrmBooleanProperty(); new_withindustry.Name="new_withindustry"; new_withindustry.Value= new CrmBoolean(); new_withindustry.Value.Value=true; arrProps.Add(new_withindustry); // create another property CrmMoneyProperty new_industrydeal = new CrmMoneyProperty(); new_industrydeal.Name = "new_industrydeal"; new_industrydeal.Value = new CrmMoney(); new_industrydeal.Value.Value = 12345.0m; arrProps.Add(new_industrydeal); // Update the properties array on the DynamicEntity. entity.Properties.AddRange((Property[])arrProps.ToArray(typeof(Property))); // Create the update target. TargetUpdateDynamic updateDynamic = new TargetUpdateDynamic(); // Set the properties of the target. updateDynamic.Entity = entity; // Create the update request object. UpdateRequest update = new UpdateRequest(); // Set request properties. update.Target = updateDynamic; // Execute the request. UpdateResponse updated = (UpdateResponse)crmService.Execute(update); Источник: http://crmpro.blogspot.com/2009/10/u...erties-of.html
