That's the question… Many rookies have problems with decision where to put the code (or from where to call it). When you watch some beginner in NAV where the code is placed and from where it is called, you can find out that in many cases used triggers are the triggers, which in 99% are not used in the application and many Pro developers nearly do not know what the triggers are doing :-). I had a thought. To create small decision tree which can help developers to find out, which trigger will be...(read more)
Подробнее... http://dynamicsuser.net/blogs/kine/archive...ce-my-code.aspx
