http://wiki.dynamicsbook.com/index.php?tit..._Numbers_in_NAV
<...> выдержка Database versions for: 4.0 20 : Pre-release data formats (change in Session view for new Idle Time column; change in permission table to include new object types) 30 : [SP 2] Security release data formats (change in Session view, removing join to syslockinfo; change in chartable; creation of security objects) 40 : [4.1 SP 2] Release data formats (added locktimeout, locktimeoutperiod, hardrowlock and bufferedrows dbproperties) 50 : [4.2 Update 3] No actual database conversion was made 60 : [SP 3] Release data formats (alterable security option; fix for SIFT data corruption around Closing Dates; added securityoption dbproperty) 61 : Rebuilding SIFT triggers in order to correct the Sum problem 62 : Rebuilding SIFT triggers in order to correct the delete statement 63 : [SP 3 Update 8 Build 26565] Prevention of updating SIFT twice Database versions for: 5.0 80 : Release data formats (added system tables for office integration and record links; change in table descriptions for clustered property) 81 : Rebuilding SIFT triggers in order to correct the Sum problem 82 : Rebuilding SIFT triggers in order to correct the delete statement 95 : [SP 1] Removed SIFT tables and triggers, creating Indexed Views instead Database versions for: 6.0 120 : Pre-release data formats (incl. CTP1) (added several new system tables; extended record links system table) 130 : Pre-release data formats (incl. CTP2) (removed SIFT tables and triggers, creating Indexed Views instead) 140 : Pre-release data formats (removed Assembly and Relationship system tables; added enabledforservice dbproperty) Подробнее... http://blogs.technet.com/alexef/archive/20...ionNumbers.aspx
