axaptapedia: Maps
Источник: http://www.axaptapedia.com/Maps
============== Summary: '''Maps''' is a logical collection of almost identical [[table]]s. A map is a compensation for the fact that tables cannot inherit properties from one another. The critical difference is that even though Map resembles a table at first glance, it does not contain data but functions rather as a library of methods intended to be shared by several tables. Maps is located in the [[AOT]] in tables. ==Using methods== The syntax for calling a method in Maps is: Table.Map::Method(); Note that the '::' is actually a a dynamic call when using it with Maps. [[Category:Table development]] [[Category: Map development]] Источник: http://www.axaptapedia.com/Maps
| Тема | Ответов | |||
| axcoder: PowerShell + Ax | 1 | |||
| axaptapedia: Load Web Documents | 1 | |||
| axaptapedia: Maps | 0 | |||
| axcoder: AxPath is supported by axaptapedia | 0 | |||
