Solutions Monkey: Forcing NTLM on IISWebsite
Источник: http://blogs.msdn.com/solutions/arch...iswebsite.aspx
============== (1) Go to IISManager and find the identifier for your Web Site. Click on the web sites folder in IISManager and on the left side you should get the list of web sites and their identifier (2) Open a command prompt and runt the following 3 commands. Change the with the identifier value found in the previous step cd c:\inetpub\adminscripts cscript adsutil.vbs set w3svc//root/NTAuthenticationProviders "NTLM" iisreset NOTE: (1) if you want to set NTLM at a virtual direcotry level then use the below command and replace with the virutal directory name cscript adsutil.vbs set w3svc//root//NTAuthenticationProviders "NTLM" (2) To revert back to Kerberos use "Negotiate,NTLM" as the parameter (3) To check what is currently set use the below commands cscript adsutil.vbs get w3svc//root/NTAuthenticationProviders cscript adsutil.vbs get w3svc//root//NTAuthenticationProviders ============== Источник: http://blogs.msdn.com/solutions/arch...iswebsite.aspx
