Старый 18.09.2007, 15:00   #1
Malaysia: How to Run Time Add Code to AOT
Источник: http://axmas.blogspot.com/2007/09/ho...de-to-aot.html
static str 60 addValidateCode(FormName formname, TableId refTableId, FieldId
refFieldId)
#AOT
TreeNode treeNode;
TreeNode methodsTreeNode;
str oldsource;
str newsource;
str superString = "super()";
str busRuleString;
str newMethodName;
str newMethodCode;
treeNode = TreeNode::findNode(#FormsPath + "\" + formName);
treeNode = treeNode.AOTfindChild("Data Sources");
treeNode = treeNode.AOTfindChild(tableId2Name(refTableId));
if(refFieldId)
newMethodName = "validate";
newMethodCode = "public boolean validate()\n{\n boolean ret;\n
;\n ret = super() && PABusInessRules::CheckRules(element, this," +
strfmt(' %1',refFieldId) + ");\n\n return ret;\n}\n";
//bus rule string is different if applied to a fieldId
busRuleString = "super() && PABusInessRules::CheckRules(element,
this," + strfmt(' %1)',refFieldId);
treeNode = treeNode.AOTfindChild("fields");
treeNode = treeNode.AOTfindChild(fieldId2Name(refTableId,RefFieldId));
else
newMethodName = "validateWrite";
newMethodCode = "public boolean validateWrite()\n{\n boolean
ret;\n ;\n ret = super() && PABusInessRules::CheckRules(element,
this);\n\n return ret;\n}\n";
busRuleString = "super() && PABusinessRules::CheckRules(element,
this)";
methodsTreeNode = treeNode.AOTfindChild("Methods");
treeNode = methodsTreeNode.AOTfindChild(newMethodName);
if(!treeNode)
methodsTreeNode.AOTadd(newMethodName);
methodsTreeNode.AOTsave();
newSource = newMethodCode;
treeNode.AOTsetSource(newsource,false);
else
oldsource = treeNode.AOTgetSource();
// check if rule already applied
if(strscan(oldSource,busRuleString,1,strlen(oldSource)) == 0)
newSource = strReplace(oldsource,superString,busRuleString);
//new line to be inserted
treeNode.AOTsetSource(newsource);
TreeNode = TreeNode::findNode(#FormsPath + "\" + formName);
treeNode.AOTcompile();
treeNode.AOTsave();
return busRuleString;
Dynamics Mobile: How to code your own barcode enabled tasklets (Motorola and Intermec devices) Blog bot DAX Blogs 1 03.06.2014 06:34
axStart: How to find line of code with a question mark in your AOT. Blog bot DAX Blogs 0 16.04.2008 22:05
axStart: How to work with big projects with multi add-ons Blog bot DAX Blogs 0 30.12.2007 16:30
Часовой пояс GMT +3, время: 15:43.
