Старый 12.07.2007, 05:56   #1
Issues concerning X++: Getting rid of the "Loss of precision" warning message
Источник: http://blogs.msdn.com/x/archive/2007...g-message.aspx
A question came up at today's webinar where a developer had a (presumably legitimate) reason to cast a real value into an integer value. The X++ language does not allow explicit casting (there's no support for it in the language), but the compiler will do its best to satisfy the user and do the conversion on its own. In this case, however, it issues a warning message, lest this is not what the user wanted.
One solution is to use the anytype type to hold the vaue for conversion and then using the any2int function, as shown below:
static void Job47(Args _args)
{ real r = 3.13;
int i = r; // Warning is issued here
anytype a;
a = r; // Assign to an anytype variable...
i = any2int(a); // ... and back into an int
print r;
print i;
pause;
This should be packaged into a function, maybe called int RealToInt(real arg).
Another way would be doing the conversion in managed code (through the System.Convert::ToInt32(object) method), but the performance will not be as good because of the marshalling that needs to take place.
I hope this helps.
Issues concerning X++: Pen based form demo Blog bot DAX Blogs 0 31.10.2007 23:40
Issues concerning X++: Difference between " and ' ? Blog bot DAX Blogs 0 30.10.2007 05:03
axaptafreak: Send message to online user in Dynamics AX 4.0 (quick & dirty) Blog bot DAX Blogs 0 12.04.2007 16:10
поле "Документы к обновлению" в форме "Обработка закупки" sev DAX: Функционал 3 08.12.2005 17:21
"LIKE" и "OR" в "qbds" @x DAX: Программирование 14 20.01.2004 13:20
Часовой пояс GMT +3, время: 18:10.
