axaptapedia: Change table owner
Источник: http://www.axaptapedia.com/Change_table_owner
============== Summary: This is more a MSSQL-tips, but it can be usefull for Axapta when you attach a existing database to your MSSQL-server. Sometimes the user of the attached database has the same name as the one already declared in MSSQL-server. Then use this code to generate another code who change the ownershop of each table in the attached database: SELECT 'exec sp_changeobjectowner ''' + ltrim(u.name) + '.' + ltrim(s.name) + ''',' + '''dbo''' FROM sysobjects s,sysusers u WHERE s.uid = u.uid AND u.name 'dbo' AND xtype in ('V', 'P', 'U') AND u.name not like 'INFORMATION%' order by s.name This scripts do actual update: declare @@name nvarchar(517) declare tables cursor for select u.name + '.' + o.name from sysobjects o inner join sysusers u on (o.uid = u.uid) where type in ('U', 'V') and u.name = 'bmssa' -- Name ^^^^^ sholuld be replaced open tables fetch from tables into @@name while @@fetch_status = 0 begin exec sp_changeobjectowner @@name, 'dbo' fetch from tables into @@name end close tables deallocate tables --[[User:Codewire.net|CODEWIRE.NET]] 06:36, 12 March 2007 (EDT) Источник: http://www.axaptapedia.com/Change_table_owner |
