Старый 22.01.2007, 17:24   #1
oleg_e is offline
oleg_e
Angry Установка Ax 4.0
Установка axapta 4.0 завершилпась неудачно. Не были установлены Aos и Client.
Пробовал и интернационалбную версию и sp1. Привожу сообщения (только при возникновенни ошибок) в логе по установке.
У кого какие мысли?
AOS.1: Regasm C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\regasm.exe "D:\Program Files\Microsoft Dynamics AX\40\Server\Ax4_Demo\Bin\Microsoft.Dynamics.IntegrationFramework.dll"
RegAsm error: Failed to load 'D:\Program Files\Microsoft Dynamics AX\40\Server\Ax4_Demo\Bin\Microsoft.Dynamics.IntegrationFramework.dll' because it is not a valid .NET assembly
Error during setup of Object server.. Reason: Error unregistering Microsoft.Dynamics.IntegrationFramework.dll. Program run: C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\regasm.exe. Parms: "D:\Program Files\Microsoft Dynamics AX\40\Server\Ax4_Demo\Bin\Microsoft.Dynamics.IntegrationFramework.dll" /unregister
=== Setting up Client ===
Launching MSI: /i "E:\MS Dynamics AX 4.0 International\AXAPTA40_International\Msi\Client\Client.msi" /qb-! /l*v "C:\Documents and Settings\All Users\Application Data\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2007-01-22 16-21-17\Client Log.txt" DIRECTEXECUTE=1 INSTALLDIR="D:\Program Files\Microsoft Dynamics AX\40\Client" CLIENTAOSSERVER="OLEG" INSTALLLANGUAGE="EN-US" LICENSE=EN-US AOS2="Ax4_Demo@OLEG" ADDLOCAL="hENUS,Debugger,License,Config"
Client.1: regasm "D:\Program Files\Microsoft Dynamics AX\40\Client\Bin\Microsoft.Dynamics.AnalysisServices.dll"
RegAsm error: Failed to load 'D:\Program Files\Microsoft Dynamics AX\40\Client\Bin\Microsoft.Dynamics.AnalysisServices.dll' because it is not a valid .NET assembly
Error during setup of Client.. Reason: Error unregistering "D:\Program Files\Microsoft Dynamics AX\40\Client\Bin\Microsoft.Dynamics.AnalysisServices.dll". Program run: C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\regasm.exe. Parms: "D:\Program Files\Microsoft Dynamics AX\40\Client\Bin\Microsoft.Dynamics.AnalysisServices.dll" /unregister
С уваженеим, Олег
ax4.0
Dynamics AX: Managing Your Supply Chain Using Microsoft Dynamics AX 2009 - Book Review Blog bot DAX Blogs 0 31.03.2009 23:06
Inside Dynamics AX 4.0: Usage Scenarios Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 16:35.
