Старый 21.11.2006, 20:52   #1
axaptafreak: Adding Favorites programmatically
Источник: http://axaptafreak.blogspot.com/2006...matically.html
In Dynamics Ax 4.0, each user can have a Favorites pane. Normally, you can add a menu item to the Favorites pane by dragging and dropping it. I created a small job where you can see how to add a form programmatically to the Favorites pane. (The job has been created using some standard methods).
The job can be downloaded from Axaptapedia here: http://www.axaptapedia.com/images/6/...oFavorites.xpo
The Axaptapedia page for this is: http://www.axaptapedia.com/Adding_Fa...ogrammatically
Next steps can be: adding a query to the favorite via X++, add a button on each form to add it to favorites
axaptafreak: Label for query range cannot be modified in AX 5.0 Blog bot DAX Blogs 0 30.08.2007 16:50
axaptafreak: Be careful when resetting your usage data Blog bot DAX Blogs 0 05.06.2007 02:28
axaptafreak: User interface changes in SP1 for Dynamics AX 4.0 Blog bot DAX Blogs 4 16.04.2007 12:49
Kashperuk Ivan: Adding Menu ReferencesMany developers often find... Blog bot DAX Blogs 0 26.01.2007 05:51
axaptafreak: Semicolon in classes: another hint Blog bot DAX Blogs 0 10.11.2006 01:14
Часовой пояс GMT +3, время: 02:32.
