Старый 19.03.2023, 23:13   #1
daxrunbase: DMF TransferStatus to check entity processing
Источник: https://www.daxrunbase.com/2023/03/1...ty-processing/
When we work with a Data Entity in D365FO, it can get tricky to track how transfers are going and how much is left. Here is a quick SQL snippet to query staging tables to figure out DMF TransferStatus: select executionid, transferstatus, case when transferstatus = 0 then 'Not started' when transferstatus = 1 then [...]
The post DMF TransferStatus to check entity processing appeared first on DAXRunBase.
atinkerersnotebook: Configuring a BYODB and Creating a Full and Incremental Entity Export Blog bot DAX Blogs 0 25.05.2018 15:11
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
dennis365foroperations: Yes, it’s here! The Copy configurations feature (and a look at other improvements related to Data Management) Blog bot DAX Blogs 0 12.10.2017 16:11
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 06:54.
