Art Of Creation: The imported project Microsoft.Dynamics.Framework.Tools.BuildTasks.targets was not found
Источник: http://www.artofcreation.be/2021/01/...was-not-found/
============== Hi everyone, I was setting up a build for Dynamics 365 F&O using the following guide: Azure hosted build for Dynamics 365 Finance & SCM and ran into the following error on the build solution step: Error MSB4019: The imported project Microsoft.Dynamics.Framework.Tools.BuildTasks.targets was not found. Confirm that the path in the declaration is correct, and that the file exists on disk.Digging a bit deeper, it was already going wrong in the NuGet install Packages step with errors like the following: Feeds used:The error was in the nuget.config file, that should point to the correct feed. For some reason the path was missing, causing the error. The incorrect file was: </span span style="color: #000066;"version/span=span style="color: #ff0000;""1.0"/span span style="color: #000066;"encoding/span=span style="color: #ff0000;""utf-8"/spanspan style="color: #000000; font-weight: bold;"?> </span> </span> </span> </span> The corrected file: </span span style="color: #000066;"version/span=span style="color: #ff0000;""1.0"/span span style="color: #000066;"encoding/span=span style="color: #ff0000;""utf-8"/spanspan style="color: #000000; font-weight: bold;"?> </span> </span> </span> </span> The correct contents of this file for your project and feed can be retrieved when you go to you DevOps project > Artifacts > [Select your feed] > Connect to Feed > NuGet.exe. Источник: http://www.artofcreation.be/2021/01/...was-not-found/
Опции просмотра | |
