Старый 19.12.2019, 10:11   #1
crmtipoftheday: Tip #1319: Double the single quotes
Источник: https://crmtipoftheday.com/1319/doub...single-quotes/
tl;dr
If you have email addresses coming from somewhere and you’re using them in Power Automate to filter and find the records, make sure to double the quotes.
Full story
One of the observations made by our lifetime tipster Jerry Weinstock was that citizens tend to create automations that follow happy path. I have to say this turned out to be valid for yours truly as well.
Am I becoming a citizen?! o__O
The Enabler
I was processing some records that came from a spreadsheet and needed to look up CDS records by email. That part of my flow looked something like this:
Happy – 3000, unhappy – 2. Diving in.
That explains it. According to RFC5322, the recipient part may use any of these ASCII characters:
  • Uppercase and lowercase English letters (a–z, A–Z)
  • Digits 0 to 9
  • Characters ! # $ % & ‘ * + – / = ? ^ _ ` { | } ~
  • Character . (dot, period, full stop) provided that it is not the first or last character, and provided also that it does not appear two or more times consecutively (e.g. John..Doe@example.com)
All of these characters are probably fine except the quote that breaks the fragile syntax of JSON land. So the expression catering for unhappy path has become:
And everyone is happy now, including the unhappy path with 6 quotes in a row.
crmtipoftheday: Tip #1103: Chart styling cheat sheet Blog bot Dynamics CRM: Blogs 0 08.04.2018 03:03
crmtipoftheday: Tip #1101: Add a scale break to charts Blog bot Dynamics CRM: Blogs 0 07.04.2018 04:03
crmtipoftheday: Tip #1097: Change chart labels on currency values to show in Millions or Thousands Blog bot Dynamics CRM: Blogs 0 04.04.2018 08:11
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Часовой пояс GMT +3, время: 07:14.
