Старый 08.07.2019, 18:12   #1
axaptacorner: Create Query dynamically in AOT through code:
Источник: http://axaptacorner.blogspot.com/201...t-through.html
static void CreateQueryInAOT(Args _args)
TreeNode treeNodeObj;
Query queryObj; // Extends TreeNode class.
QueryBuildDataSource qbds;
QueryBuildRange qbr;
QueryRun qr;
CustTable xrecCustTable;
str queryName = "TestQuery";
// Macro.
#AOT
// Delete the query from the AOT, if the query exists.
treeNodeObj = TreeNode::findNode(#QueriesPath);
treeNodeObj = treeNodeObj.AOTfindChild(queryName);
if (treeNodeObj) { treeNodeObj.AOTdelete(); }
// Add the query to the AOT.
treeNodeObj.AOTadd(queryName);
queryObj = treeNodeObj.AOTfindChild(queryName);
// Further define the query.
qbds = queryObj.addDataSource(tablenum(CustTable));
qbr = qbds.addRange(fieldnum(CustTable, CustGroup));
qbr.value("Inter");
// Compile the query.
queryObj.AOTcompile(1);
queryObj.AOTsave();
// Run the query.
qr = new QueryRun("TestQuery");
while ( qr.next() )
xrecCustTable = qr.GetNo(1); // 1 means first data source.
Global::info(strFmt("%1 , %2",
xrecCustTable.AccountNum, xrecCustTable.CustGroup));
axaptacorner: How to find SQL query out of the AOT query: Blog bot DAX Blogs 0 08.07.2019 18:12
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
vasantharivali: Using AOT Query Object in X++ Code Blog bot DAX Blogs 0 17.11.2012 11:12
axaptacorner: How to create Query in AX 2012 through X ++ code Blog bot DAX Blogs 0 20.09.2012 17:11
Часовой пояс GMT +3, время: 14:49.
