Старый 16.11.2018, 16:11   #1
d365technext: Compare Records D365FO & AX 2012
Источник: http://d365technext.blogspot.com/201...o-ax-2012.html
How to compare two records buffer field to field.
publicstaticcontainer compareRecords(Common _record1, Common _record2)
SysDictTable dictTable =new SysDictTable(_record1.TableId);
SysDictField dictField;
FieldId fieldId, extFieldId;
container ret;
int i, j;
if(_record1.TableId!= _record2.TableId)
returnconNull();
for(i=1; i<=dictTable.fieldCnt(); ++i)
fieldId = dictTable.fieldCnt2Id(i);
dictField =new SysDictField(_record1.tableId, fieldId);
if(!dictField.isSystem())
for(j=1; j<= dictField.arraySize(); ++j)
extFieldId = fieldId2Ext(fieldId, j);
if(_record1.(extFieldId)!= _record2.(extFieldId))
ret +=[extFieldId, _record1.(extFieldId), _record2.(extFieldId)];
return ret;
For Demo purpose you can use below code in job/runnable class.
static void demoCompareRecords(Args _args)
VendTable vendTable_1 = VendTable::find('ABC');
VendTable vendTable_2 = VendTable::find('XYZ');
container con;
int i;
con = MyClass::compareRecords(vendTable_1 , vendTable_2 );
for (i=1; i
d365technext: Record sorting D365FO, AX 7 and AX-2012 Blog bot DAX Blogs 0 08.08.2018 21:12
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
dynamics-ax: Microsoft Dynamics AX 2012 Learning Plans & The Important 'Solutions Architect' Role Blog bot DAX Blogs 0 22.06.2011 21:12
Часовой пояс GMT +3, время: 03:42.
