Старый 10.11.2018, 09:20   #1
dynamicsaxinsight: D365: Reverse customer transaction in X++
Источник: https://dynamicsaxinsight.wordpress....action-in-xpp/
Purpose:
The purpose of this document is to demonstrate how we can reverse a posted customer transaction through X++. The code below can be used as a script to automate reversal of posted customer transactions.
Product:
Dynamics 365 for Finance and Operations
Development:
Please find below the code which can be used to reverse a posted customer transaction. It will actually create and post a negative entry transaction against the transaction to reverse. Please note the code defaults reason code to “ERROR” while posting a reversal transaction. Once developed this can be triggered using the following URL:
https://usnconeboxax1aos.cloud.onebo...tTransReversalCode:
class MAKCustTransReversal extends TransactionReversal_Cust{ public static MAKCustTransReversal construct() { return new MAKCustTransReversal(); } public boolean showDialog() { return false; } public static void main(Args _args) { CustTrans custTrans; MAKCustTransReversal makCustTransReversal; ReasonTable reasonTable; ReasonCode reasonCode; ReasonRefRecID reasonRefRecID; InvoiceId invoiceId; Args args; ; invoiceId = "3392"; reasonCode = "ERROR"; reasonTable = ReasonTable::find(reasonCode); reasonRefRecID = ReasonTableRef::createReasonTableRef( reasonTable.Reason, reasonTable.Description); custTrans = CustTrans::findFromInvoice(invoiceId); if (custTrans.RecId && !custTrans.LastSettleVoucher) { args = new Args(); args.record(custTrans); makCustTransReversal = MAKCustTransReversal::construct(); makCustTransReversal.parmReversalDate(systemDateGet()); makCustTransReversal.parmReasonRefRecId(reasonRefRecID); makCustTransReversal.reversal(args); info(strFmt("%1 %2 %3 %4 reversed.", custTrans.Voucher, custTrans.TransDate, custTrans.Invoice, custTrans.Txt)); } }}
dynamicsaxinsight: AX7/D365/Operations: Create customer postal address through data entity from .NET console application Blog bot DAX Blogs 0 20.09.2017 15:11
dynamicsaxinsight: AX7/D365/Operations: Create Details Master pattern form Blog bot DAX Blogs 0 14.09.2017 13:11
dynamicsaxinsight: AX7/D365/Operations: Create custom data entity Blog bot DAX Blogs 0 14.09.2017 13:11
Inside Dynamics AX 4.0: Transaction Semantics Blog bot DAX Blogs 0 31.10.2007 23:40
Часовой пояс GMT +3, время: 16:56.
