Старый 22.09.2018, 08:24   #1
ievgensaxblog: MSDyn365FO. How-to pass generic types to .Net method
Источник: https://ievgensaxblog.wordpress.com/...to-net-method/
There is a wonderful blog post about Generic types in X++. And as It says, the easiest way to work with generic types in X++ is to create .Net library and expose non-generic interface, because X++ compiler has lots of limitations.
However, if you really want to have some fun and stick to X++, it’s possible with a help of reflection.
Let’s say we have a C# class that accepts  List and we want to invoke it from X++:
public class Class1{ public static string myMethod(List list) { string res = string.Empty; foreach (var array in list) { foreach (string s in array) { res += s; } }return res; }}We cannot simply declare:
var stringList = new System.Collections.Generic.List();
Looks like X++ parser cannot handle “
ievgensaxblog: D365FOE. How to override form data source field lookup method. Blog bot DAX Blogs 0 10.01.2018 05:11
goshoom: Generic types in X++ (AX 7) Blog bot DAX Blogs 0 10.04.2017 13:11
Navigate Into Success: Try..Catch for .NET Interoperability Blog bot Dynamics CRM: Blogs 0 29.10.2014 09:00
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 12:16.
