Старый 16.09.2018, 12:18   #1
sinedax: How to avoid Retail Module configuration reset - Dynamics 365 for Finance & Operations LBD
Источник: http://sinedax.blogspot.com/2018/09/...il-module.html
Hi mates,
if in your LBD implementation the Retail Module disappear after a Deployment, here how to avoid it.
After a chat with Microsoft, to prevent DB sync from resetting the config keys (Retail in my case), issue the following command against the AxDB Database from sql server management studio:
INSERT INTO SQLSYSTEMVARIABLES (PARM, VALUE, IPARM, IVALUE) VALUES ('FirstSyncSuccess', 1, 20, NULL)
It seems that in the next months a new KB will be release in order to fix that.
In the next Deployments you can sleep peacefully that the Retail Module will be there again!
Till soon!
atinkerersnotebook: New Bare Bones Configuration Guide is Available for Dynamics 365 for Operations Blog bot DAX Blogs 0 17.11.2016 18:11
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
Часовой пояс GMT +3, время: 02:14.
