Старый 18.08.2018, 12:27   #1
d365technext: Long Processing Dialog D365FO
Источник: http://d365technext.blogspot.com/201...og-d365fo.html
There is a class in Dynamics 365FO Named SysOperationSandbox which is handle long running dialog for long running processes.. this class support Class and table level static method only..
Following are the Parameters
  • Class / Table name
  • Method Name
  • Container
  • Caption Message
  • Completion Message
  • Failure Message
Form Code
[Form]
public class SLD_DemoForm extends FormRun
[Control("Button")]
class FormButtonControl1
public void clicked()
container _container=["You can pass parameter to your method",1000];
SysOperationSandbox::callStaticMethod(classNum(SLD_DemoInstance),
staticMethodStr(SLD_DemoInstance,LongProcess),_container,
'waiting caption should be here', 'Operation completed message should be here','Operation Cancelled should be here');
super();
Class Code
<div>class SLD_DemoInstance
public static void LongProcess(container _container)
int contervalue= conPeek(_container,2);
<div class="MsoNormal"> for (int i=1<span style="font-family: "consolas"; font-size: 9.5pt;">;i
d365technext: Environment hot fixes D365FO Blog bot DAX Blogs 0 16.08.2018 14:11
d365technext: SSRS Report with custom fonts in D365FO Blog bot DAX Blogs 0 15.08.2018 17:15
d365technext: D365FO Database Synchronization Blog bot DAX Blogs 0 10.08.2018 19:11
d365technext: Label Extension D365FO Blog bot DAX Blogs 0 07.08.2018 19:11
Microsoft Dynamics CRM Team Blog: Welcome to the World of Dialogs - Part 1 Blog bot Dynamics CRM: Blogs 0 02.02.2011 21:11
Часовой пояс GMT +3, время: 09:39.
