Старый 19.05.2017, 12:11   #1
palleagermark: Use tags to find related bits and pieces in your code base
Источник: http://www.agermark.com/2017/05/use-...-bits-and.html
A lot of elements, if not all, in Dynamics 365 for Operations (D365FO) has a property called "Tags".
With this property you can link all sorts of different otherwise unrelated elements. You could for example use this as part of a bigger change you need to do to your code base, marking all the bits you need to modify.
Adding a tag is as simple as just using it:
For Visual Studio to find places where the tag is used, you need to do a build with the "Build cross reference data" option checked:
And here is where you search for tags:
And here is the result:
This ought to work for code to. The editor knows about the tags and has intellisense for them:
But the "Find tag references" tool doesn't pick them up. I wonder if that is a bug or not.
And in my opinion you should try to not go overboard tagging away all day long.
daxmusings: Design-Compile-Run Part2: Design, Compile, Run in AX 2012 Blog bot DAX Blogs 0 04.05.2016 13:11
palleagermark: Send tweets from AX via the Retail module Blog bot DAX Blogs 0 16.09.2014 22:11
palleagermark: Translate text with Microsoft Translator from AX Blog bot DAX Blogs 0 08.11.2013 15:11
palleagermark: XML transformation from Excel spreadsheet Blog bot DAX Blogs 0 22.11.2012 14:11
Microsoft Dynamics CRM Team Blog: Fetch-Xml based Reports: Bits & Pieces Blog bot Dynamics CRM: Blogs 0 24.02.2011 21:11
Часовой пояс GMT +3, время: 21:04.
