How to see beginning balance journals from your projects
Источник: http://alexvoy.blogspot.com/2016/11/...-journals.html
============== There is a bug in AX 2012 R2/R3. Beginning balance journals do not create transactions in ProjJournalTrans table; therefore, they won't be selected via the standard query. This is a small fix to show beginning balance journals from the projects forms. In ProjJournalFormTable class we need to redo datasourceLinkActivePre() method as follows: public void datasourceLinkActivePre() { QueryBuildDataSource qbds; ProjTable callerRecord; if (formRun && formRun.args() && formRun.args().record() && formRun.args().dataset() == tableNum(ProjTable)) { callerRecord = formRun.args().record() as ProjTable; // if this is a beginning balance table we have no transactions in ProjJournalTrans // therefore, we need to update the query so that all related journals will be shown. if(journalTypeId == 2) // beginning balance { SysQuery::findOrCreateRange(journalTable_ds.query().dataSourceTable(tableNum(ProjJournalTable)), fieldNum(ProjJournalTable, JournalType)).value(SysQuery::value(ProjJournalType::BegBalance)); SysQuery::findOrCreateRange(journalTable_ds.query().dataSourceTable(tableNum(ProjJournalTable)), fieldNum(ProjJournalTable, ProjId)).value(SysQuery::value(callerRecord.ProjId)); } else { // End qbds = journalTable_ds.query().dataSourceNo(1).addDataSource(tableNum(ProjJournalTrans)); qbds.joinMode(JoinMode::ExistsJoin); qbds.addRange(fieldNum(ProjJournalTrans, ProjId)).value(callerRecord.ProjId); qbds.relations(true); } } super(); } Источник: http://alexvoy.blogspot.com/2016/11/...-journals.html
