Старый 26.11.2016, 19:16   #1
organicax: CU12 for Dynamics AX 2012 R3 is available.
Источник: https://organicax.com/2016/11/26/cu1...-is-available/
If you are working on an AX2012 R3 implementation you might want to have a look at CU12 that was just released. You can read the What’s new document here.
There are some nice updates to technology support like SQL2016 and some functional updates along with fixes. For example being able to run a depreciation run across companies, which is nice if you have many legal entities that you use fixed assets for. This feature was in the fall release of D365 as well.
The KB was listed as KB3199741 which you can find on partnersource here. As well you can find it under the updates tile on Lifecycle Services.
Cheers
Lachlan
Filed under: Lifecycle Services, Microsoft Dynamics AX
axperf: Multiple new Benchmarks released: Microsoft Dynamics AX 2012 R2 Multiple Retail Workloads, Microsoft Dynamics AX 2012 R3 Financial Benchmark, Microsoft Dynamics AX 2012 R3 Day in the Life Benchmark for Retail and Distribution Blog bot DAX Blogs 5 13.01.2015 14:26
emeadaxsupport: [AX 2012 R3] Why is my Kernel build version not changing after installing CU-8 or the latest binary hotfix? Blog bot DAX Blogs 0 31.12.2014 20:20
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2012 R3 RTM Warehouse Management: How to prevent the creation of two inventDim records considered identical in Dynamics AX 2012 R3 RTM Blog bot DAX Blogs 0 22.12.2014 19:12
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 10:52
Часовой пояс GMT +3, время: 09:24.
