Старый 10.11.2016, 08:14   #1
emeadaxsupport: Financial dimensions that contain the same character as used in the chart of accounts delimiter
Источник: https://blogs.msdn.microsoft.com/axs...nts-delimiter/
In Dynamics 365 Operations (AX7) if a financial dimension contains the same character as the chart of accounts delimiter you may experience some instability. The Chart of Accounts delimiter is set on the general ledger parameters and once this is setup the field is greyed out. (Previously this field was located in the system parameters)... Read more
axsa: Planning your chart of accounts in AX 2012 (Part 2 of 7) Blog bot DAX Blogs 0 24.06.2014 07:12
dynamicsaxtraining: Basic concepts Blog bot DAX Blogs 0 24.02.2012 07:12
dynamicscpm: Creating Consolidated Financial Statements using Management Reporter – Consolidating data across one or multiple Dynamics ERPs with different chart of accounts (Part 2 of 7) Blog bot DAX Blogs 0 05.01.2012 05:11
sumitsaxfactor: Ledger Accounts and Financial Dimensions Blog bot DAX Blogs 0 13.12.2011 22:11
Часовой пояс GMT +3, время: 07:18.
