Старый 20.07.2016, 15:11   #1
palleagermark: Moving label files between models in AX7
Источник: http://www.agermark.com/2016/07/movi...ls-in-ax7.html
When you need to move label files between models in AX 7, there are a couple of thing to remember.
  • A label file consists of several files.
    Under \AxLabelFile there is an XML file for each language with some metadata about the label files.
    And then again under \LabelResources you'll find the actual label files for each language.
  • In the XML files with the metadata about the labels your need to modify the RelativeUriInModelStore property to reflect the new location.
  • You should move the above files from VSTS, so you keep version history of earlier changes.
  • If you did an earlier build, you must manually remove the compiled dll's for earlier compiled labels files. You'll find these in the Resources folder for the model you moved the files from. There is a dll directly in the folder, and one in the subfolder for each language. If you don't remove the dll's, AX might keep using the old and wrong version.
You might want to move the label files from under ApplicationSuite, where the LCS upgrade tool puts your custom label files, into a new extension model.
german_nav_developer: Buildnummern-Übersicht Microsoft Dynamics NAV 2013 R2 Blog bot NAV: Blogs 0 15.05.2016 18:12
palleagermark: Working with Excel files in AX7 Blog bot DAX Blogs 0 28.12.2015 10:11
palleagermark: Quick import of new label files Blog bot DAX Blogs 0 01.07.2015 12:11
palleagermark: How to delete Label Files from AX 2012 Blog bot DAX Blogs 0 22.01.2014 15:11
Часовой пояс GMT +3, время: 22:33.
