In NAV 2009, there have been issues posting some documents containing Item Tracked lines.
This entry brings together 3 KB articles which address these issues, with the intention that a system could be patched with all the relevant fixes at the same time. When encountering the following generic error, users can refer to the articles first, in order to identify if a suitable solution already exists and therefore resolve the problem in a timely manner: Qty. to Handle (Base) in Tracking Specification for Item No. [item no.], serial no.: Serial No., lot no.: Lot No., is currently [quantity 1]. It must be [quantity 2]. KB 2536288 – NAV 2009 SP1 When you try to post a transfer order line that has the defined Item Tracking for shipment in Microsoft Dynamics NAV, you receive the following error message: Qty. to Handle (Base) in Tracking Specification for Item No. Item No. , Serial No.: Serial No. , Lot No.: Lot No. is currently Qty.1 . It must be Qty.2 . KB 977259 – NAV 2009 – fixed in SP1 Error message when you post a warehouse shipment after registering picks for a lot tracked item Qty. to handle (base) in tracking specification for item [item number] serial no., lot no., [lot number] is currently - [quantity 1] , it must be - [quantity 2] . https://mbs2.microsoft.com/Knowledge...b;EN-US;977259 KB 983575 – NAV 2009 SP1 When you try to post a warehouse shipment for a lot tracked item in Microsoft Dynamics NAV 2009 SP1, you receive the following error: qty. to handle(base) in tracking specification for item no. Item No. , serial no.: Serial No. , lot no.: Lot No. , is currently Quantity . it must be Quantity (base) https://mbs2.microsoft.com/Knowledge...b;EN-US;983575 Источник: http://feedproxy.google.com/~r/Micro...ing-lines.aspx
