Старый 09.04.2009, 22:05   #1
Jim Wang: Customizing CRM by Using the Microsoft Dynamics CRM Developer Toolkit
Источник: http://jianwang.blogspot.com/2009/04...microsoft.html
Thanks Microsoft CRM E2 team to provide this useful Toolkit for CRM developers.
To provide developers with the ability to create and manage on-premise CRM solutions in an integrated Visual Studio environment, the Microsoft Dynamics CRM Engineering for Enterprise (CRM E2) team initiated and sponsored the development of the Microsoft Dynamics CRM Developer Toolkit. The toolkit includes two primary components:
The CRM Explorer
The CRM Explorer complements the CRM
Solution Framework, providing the project factories required to open and build
the solution from within Visual Studio. The Explorer manifests as a window
within Visual Studio 2008 and provides direct access to CRM for creating and
editing business units, security roles, and most importantly, entities. The CRM
Explorer is linked to the solution framework which enables it to intelligently
place generated code into the relevant solution framework project.
The CRM Solution Framework
The CRM Solution Framework is a suite of Visual Studio C# projects that are coupled with CRM Entity customizations and wrapped with extensible MSBuild–based developer builds and daily builds. The Framework contains several “pre-canned” projects for the typical tasks that are required of developers when undertaking most Enterprise-level CRM projects. Several of these projects have an inheritance model that affords simple and intuitive augmentation, which can significantly reduce the time required to “jump start” development of new projects.
Software Requirements
Microsoft Dynamics CRM 4.0
Visual Studio 2008 Professional
Visual Studio Team Explorer
StyleCop 4.3 or later (full installation, including MSBuild Integration files)
.NET 3.5 SP1
Installation:
1. Install the CRM Explorer(under folder \CRM Explorer\setup.exe)
2. Install the CRM Solution Framework(under folder \CRMSolutionFrameworkTemplate\Setup.cmd)
Use command prompt to install: Setup.cmd {InstallDir} {ProjectName} {Project Long Name} {Organization Name}
Configuration:
1. Load the project UKDynamics first(Load project normally), then build the solution.
2. Load the project MyCrmSolution(Load project normally), it will referce the UKDynamics class on the step 1. *[1] *[2]
3. From Visual Studio menu bar, click [Tools], then select the [Connect to CRM Server...], give the information then click [OK] button;
4.From Visual Studio menu bar, click [View], then select the [Other Windows]>>[CRM Explorer] *[3]
*[1] If you get warnings like: The referenced component 'UKDynamics.Instrumentation' could not be found. Then you need to re-add the dll reference(UKDynamics.Instrumentation.dll) from UKDynamics\bin folder.
*[2] If you get errors like: The command ""C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin\gacutil" /i "C:\Projects\MyCrmSolution\SourceCode\MyCrmSolution\Core\Configuration\bin\Debug\MyCrmSolution.Core.Configuration.dll" /f" exited with code 1. Configuration
It because all assemblies are delay-signed, you can turn off the strong-name verification on the dev environment by using the SN tool from Visual Studio 2008 Command Prompt: SN.exe -Vr *,*
then run IISRESET.exe
*[3] If you get errors when expand the item, like:
Client found response content type of 'text/html; charset=utf-8, but expected 'text/xml'. HttpException 1310
Exception message: Could not load file or assembly 'MyCrmSolution.Core.BusinessProcesses, Version=1.1.0.0, Culture=neutral, PublicKeyToken=2c1937e0898110b2' or one of its dependencies. Strong name signature could not be verified. The assembly may have been tampered with, or it was delay signed but not fully signed with the correct private key. (Exception from HRESULT: 0x80131045)
It is the same reason and solution with *[2]
Note: The Toolkit is based on components that were initially developed within the Dynamics CRM MCS team in the UK subsidiary. Those components have been refined over a number of UK-based global engagements.
Important: The Microsoft Dynamics CRM Developer Toolkit currently supports customization of on-premise CRM deployments only. This Toolkit and the accompanying documentation are unsupported and are being provided “as is” by the CRM E2 team to assist developers with managing and extending their on-premise Microsoft Dynamics CRM implementations.
Полезные ссылки по MS CRM. IgorF Dynamics CRM: Прочие вопросы 60 24.05.2013 16:19
Microsoft Dynamics CRM Team Blog: Highlight: Available downloads for Microsoft Dynamics CRM Blog bot Dynamics CRM: Blogs 0 05.11.2008 22:05
Microsoft Dynamics CRM Team Blog: Top 14 Microsoft Dynamics CRM Sites and Downloads Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 05:21.
