Старый 07.04.2016, 20:13   #1
organicax: Receipt date is not valid on customer calendar
Источник: http://organicax.com/2016/04/07/rece...omer-calendar/
If you are entering a sales order and change the receipt date on the line and receive a message
The entered receipt date mm/dd/yyyy is not valid because it is not an open date in the customer calendar
Then you might want to check the receipt calendar assigned to the customer master. More than likely the date is closed for receiving goods on the date that was entered.
Here is a quick overview.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Sales and marketing, Supply chain planning
emeadaxsupport: The error message "The transactions on voucher XXX do not balance as per [date]. (accounting currency: 50,00 - reporting currency: 50,00)" in open customer transactions settlement Blog bot DAX Blogs 0 13.10.2014 21:11
goshoom: Target date not found in work calendar Blog bot DAX Blogs 0 30.01.2014 16:11
Axilicious:Hosting custom WPF calendar control in AX 2012 Blog bot DAX Blogs 0 20.05.2013 18:11
daxmusings: Valid Time State/Date Effective Framework - Part2 Blog bot DAX Blogs 6 07.10.2011 11:22
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 02:47.
