Старый 28.04.2015, 02:22   #1
emeadaxsupport: Return material adjustment (RMA) processing through the mobile device
Источник: http://blogs.msdn.com/b/axsupport/ar...le-device.aspx
This blog post assumes a working knowledge of the new
Warehouse management module released in Microsoft Dynamics AX 2012 R3.
The process of receiving a Return material adjust (RMA)
using the new WMS mobile device functionality is very similar to processing an
inbound transaction such as a purchase order. The following steps are intended
as a walkthrough of the necessary setup and actions required to complete the
process. They are completed against the USMF Contoso dataset on a CU8 installation.
1)
Setup a Return order work template
  1. Warehouse > Work > Work Templates
  2. Change the Work order type to “Return orders”
  3. Create a new work template by clicking the New
  1. Create new work type lines by clicking the New
    button on the low section of the grid
  2. Create two lines
i.
The first
ii.
Work type = Pick
iii.
Mandatory = Checked
iv.
Work class ID = Return
v.
The second
vi.
Work type = Put
vii.
Mandatory = Checked
viii.
ix.
Close the form
2)
Setup a Disposition code and link it to an
inventory status
  1. Warehouse management > Mobile device >
    Disposition codes
  2. Create a new Disposition code by clicking the
    New button
  3. The new Disposition code will need the following
    fields
i.
Disposition code: The name of the disposition
code.
ii.
Inventory status: An inventory status which will
define the blocking strategy assigned to the returned item.
iii.
Work template code: The work template to which
this disposition code should be linked.
iv.
Return disposition code: A traditional
disposition code that contains the disposition action.
  1. *Note*: Any disposition code that has an action
    of “Return to customer” will not generate work as of CU8
  2. Create the record with the following values
i.
Disposition code = Customer return
ii.
Inventory status = Available
iii.
Work template code = 51 Return Order
iv.
Return disposition code = 11
v.
Close the form
3)
Create a location directive to manage the Return
order process in the warehouse
  1. Warehouse management > Setup > Location
    directives
  2. Change work order type to “Return orders”
  3. In the Location directives fast tab click New
i.
Sequence number = 1
ii.
Name = 51
iii.
Work type = Put
iv.
Site = 5
v.
Warehouse = 51
vi.
Disposition code = Customer return (the
disposition code must be specified or the location directive will not be
found).
  1. In the Lines fast tab click New
i.
Sequence number = 1
ii.
From quantity = 1
iii.
To quantity = 999,999
iv.
Locate quantity = None
  1. In the Location Directives Actions Click New
i.
Sequence number = 1
ii.
Name = Put
iii.
Fixed location usage = Fixed and non-fixed
locations
iv.
Strategy = None
  1. In the Location Directive Actions fast tab click
    Edit Query
  2. Set the Location Criteria = Bulk-001
  1. Click OK to close the form
  2. Close the Location directives form
4)
Create a menu item on the Mobile device
  1. Warehouse management > Setup > Mobile
    device > Mobile device menu items
  2. Click New to create a new menu item
i.
Menu item name = RMA Process
ii.
Title = RMA Process
iii.
Mode = Work
iv.
Work creation process = Return order receiving
v.
Close the form
5)
Add the new mobile device menu item to the
mobile device
    device menu
  2. In the Available menus and menu items section
    find the RMA process and add it to the menu structure by clicking the “ Common > Return
    orders > All return orders
  3. In the panel click Return orders> New >
    Return order
i.
Customer account = US-004
ii.
Click OK to create the return orders
  1. Add a line to the return order
i.
Item number = A0001
ii.
Site = 5
iii.
Warehouse = 51
iv.
Unit price = 5
v.
Quantity = -1
vi.
Copy the RMA number on the Return order header
(General fast tab)
7)
Open the Emulator in the AOT and receive the RMA
to create the work
  1. AOT > FORMS > WHSWorkExecute > Right
    click > Open
i.
User ID: = 51
ii.
Password = 1
  1. In the main menu select RMA Process
  2. Enter the RMA number click OK
  1. Item = A0001
  2. LP = TestLp
  3. Qty = 1
  4. Disposition code = Customer return
  1. Click OK
8)
Navigate back to the Return order and open the
sales order to view the work
  1. On the RMA select the sales order number to open
    the sales order for the RMA
  1. On the Sales order in the Sales order lines
    section click Warehouse > Work details
  2. Notice
    the work has been created. The pick in the receipt location and the put away is
    set to the location specified in the location directive
DynamicsAxSCM: Creating Custom Solutions with the Warehouse Mobile Device Portal Blog bot DAX Blogs 0 13.03.2015 16:11
DynamicsAxSCM: Warehouse Mobile Device Portal Architecture Blog bot DAX Blogs 0 03.03.2015 19:11
DynamicsAxSCM: Warehouse Mobile Device Portal Blog bot DAX Blogs 0 23.02.2015 22:12
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
Kashperuk Ivan: Walkthrough: Fixing error "Incorrect Mobile device display settings..." on the mobile device when trying to sign in Blog bot DAX Blogs 0 10.05.2014 06:30
Часовой пояс GMT +3, время: 20:46.
