Старый 31.05.2014, 00:14   #1
emeadaxsupport: Missing administrative permissions when working with IDMF Beta based on MS Dynamics AX 2012 R1 in French?
Источник: http://blogs.msdn.com/b/axsupport/ar...in-french.aspx
The installation was succesful, post installation tasks went to the end, the XPO projects were imported in AX, synchronisation is done and you’re sysadmin on all SQL Server instances and local Administrator of Windows servers.
The .Net business connector can connect to the AX environment as I can view a worker process when you launch the IDMF console and there is no error in the event viewer on the server where IDMF is deployed.
The macro #define.SysAdministrator('System administrator') should have been defined as a multi language capable label instead of hard coded in US English
Solution:
Go to \Classes\DMTValidateAdminUser method: vaildate user
in Standard you find there:
because this is a French Installation you have to replace this through :
#define.SysAdministrator('Administrateur Système')
idmf
DAX: Microsoft Dynamics AX 2012 R3 is now available! Blog bot DAX Blogs 1 02.05.2014 23:00
emeadaxsupport: "Parameter is missing a value" error running a customized report in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 21.11.2012 00:12
dynamics-community.at: Dynamics AX 2012 Trainings Blog bot DAX auf Deutsch 0 19.06.2012 18:11
dynamics-ax: Microsoft Dynamics AX 2012 and the use of Claims Based Security Blog bot DAX Blogs 0 08.03.2011 06:24
Часовой пояс GMT +3, время: 02:57.
