Старый 02.01.2014, 01:16   #1
goshoom: A user session cannot be created
Источник: http://dev.goshoom.net/en/2014/01/us...ot-be-created/
I installed AX2012 R2 CU7 with the demo data downloaded from Microsoft Dynamics AX 2012 Solution Demos on PartnerSource. When I attempted to start the AX client, it threw the following error:
A user session on the server could not be created. Try to start the client again. If the problem continues, contact the Microsoft Dynamics AX administrator.
I also found the following message in the Event Log:
Unable to connect to an Application Object Server. A company name or server name may not be specified correctly in the client configuration, or the server specified may not be available.
I checked the setup and everything was all right. I also looked on internet, just to find that few other people ran into the same error – but I didn’t find any solution.
I thought that “user session on the server could not be created” might have referred to missing permissions for execution of CREATEUSERSESSIONS stored procedure but it wasn’t the case either.
Then I used the SQL Server Profiler to obtain statements sent to database – as expected, CREATEUSERSESSIONS was called. I copied the command (with all parameters) and executed it by myself. And it failed! The error was:
Procedure or function CREATEUSERSESSIONS has too many arguments specified.
It was easy then to find out that the extra argument was a partition ID. Partitions were introduced in AX2012 R2 and the database obviously was from a pre-R2 environment.
There are two data set on Microsoft Dynamics AX 2012 Solution Demos:
  • Demo Data (used to restore VM-A v3 to original demo data state)
  • Demo Data (used to restore VM-A v4 to original demo data state)
Accidentally, I downloaded v3 without noticing there is another version available. When I downloaded and installed v4, everything started to work. I thought that v3 version was built upon AX2012 R2 too, however it doesn’t seem to be the case with the database.
The lesson learned isn’t only that I should be more careful about what I’m installing. The way how I managed to identify the problem is important as well and might help in other cases in future.
emeadaxsupport: Purchase Requisition Workflow in Dynamics AX 2009 fails with Stopped (error): Work item could not be created. Insufficient rights for user Blog bot DAX Blogs 0 18.11.2010 21:12
Leon's CRM Musings: Auto-assigning workflow-created records to the current user Blog bot Dynamics CRM: Blogs 0 05.02.2010 15:05
daxis: Dynamics Ax 4.0 Session Types Blog bot DAX Blogs 0 01.04.2009 18:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 15:07.
