Старый 23.12.2013, 18:11   #1
emeadaxsupport: AX Content: Multiple instances of SQL Server Reporting Services (SSRS) on one computer
Источник: http://blogs.msdn.com/b/axsupport/ar...-computer.aspx
Do you have multiple instances of SQL Server Reporting Services that run on the same computer? Do you want to integrate those instances with Microsoft Dynamics AX? If so, a Windows PowerShell command is now available with cumulative update 7 for Microsoft Dynamics AX 2012 R2 that makes the integration process a whole lot easier!
For example, assume that you have a report server that hosts three Reporting Services instances. To integrate these instances with Microsoft Dynamics AX, follow these steps:
  1. Integrate the first Reporting Services instance with Microsoft Dynamics AX. To do this, run the Microsoft Dynamics AX setup wizard to install the reporting extensions, and then deploy the reports that are included with Microsoft Dynamics AX. For more information, see Checklist: Install the Reporting Services extensions and deploy reports.
  2. Integrate the second Reporting Services instance with Microsoft Dynamics AX by running the Install-AXReportInstanceExtensions Windows PowerShell command.
  3. Integrate the third Reporting Services instance with Microsoft Dynamics AX by running the Install-AXReportInstanceExtensions command.
The following diagram summarizes this process.
For information about how to run the Install-AXReportInstanceExtensions command, see Install multiple instances of Reporting Services on the same computer (for use with Microsoft Dynamics AX).
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
emeadaxsupport: Error when deploying AX Report to SQL Reporting Server - Client found response type of 'text/html;charset=utf8;' but expected 'text/html' Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 03:42.
