Старый 15.12.2013, 22:11   #1
bojensen: Reading Selected Node in XML – Dynamics AX2012 | Santosh Ramamurthy AX Blog
Источник: http://blogs.bojensen.eu/?p=4770
Case Study: Below a sample job is illustrated to read selected (multiple) nodes from a given XML. private static void SR_ReadSelectedNode_XML(Filename fileName) { #define.node('INFORMATION//ROWS/ROW') XmlDocument xmlDocument; XmlNode xmlInformationNode; XmlNodeList xmlInformationsNodeList; XmlNodeList xmlChildNodeList; int i; int j; fileName = @'C:\Projects\ReadNode.xml'; xmlDocument = xmlDocument::newFile(fileName); xmlInformationsNodeList = xmlDocument.documentElement() .selectNodes(#node); setPrefix("@SYS98689"); for ( i = 0; i < xmlInformationsNodeList.length(); […]
kamalblogs: Issue: Dimension lookup “selected record invisible” – Dynamics AX 2012 Blog bot DAX Blogs 0 07.10.2013 13:11
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Excel to Import Customers and Vendors in Dynamics AX 2012 Blog bot DAX Blogs 0 19.07.2013 15:11
bojensen: Job to Import Vendor/Customer Postal Address in Dynamics Ax2012 | Amirs Microsoft Dynamics AX space Blog bot DAX Blogs 0 24.04.2013 15:11
Часовой пояс GMT +3, время: 11:17.
