Старый 30.11.2012, 22:11   #1
ax-erp: Independent transaction in AX
Источник: http://microsoft-dynamics-ax-erp.blo...ion-in-ax.html
Sometimes we need to write some data into a database independently on the currently running DB transaction. For example, we want to log some state occurred in the application, however any exception could cause a rollback of the whole transaction, including the log entry. It could look as follows:
LogTable logTable;
ttsbegin;
logTable.Message = "Something happens";
logTable.insert();
//some following code in the same transaction throws an exception
throw Exception::Error;
ttscommit;
It can be resolved quite easily. We need to create a separate database connection and possibly our own transaction. The modification of the preceding code would look as follows:
LogTable logTable;
UserConnection connection = new UserConnection();
ttsbegin;
//use another connection
logTable.setConnection(connection);
//beginning of the independent transaction
logTable.ttsbegin();
logTable.insert();
logTable.ttscommit();
//this exception doesn't affect the logTable entry
ttscommit;
За это сообщение автора поблагодарили: Pandasama (1).
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
Inside Dynamics AX 4.0: Transaction Semantics Blog bot DAX Blogs 0 31.10.2007 23:40
Часовой пояс GMT +3, время: 03:28.
