dynamicscpm: How to use the database deployment tool for Windows 2003
Источник: http://blogs.msdn.com/b/dynamicscpm/...dows-2003.aspx
============== This week I wanted to post an instructional video on how to use the database deployment tool. I've seen a bit of confusion and thought a tutorial would be helpful. Why would I use the database deployment tool? The database deployment tool was created to support those that need to run the Management Reporter services from a Windows 2003 machine.
The database deployment tool was released with Management Reporter 2012 Rollup 2 and is included in any release with Rollup 2 or newer.
The full documentation is available in the Installation and Configuration guide (MRforDynERPInstGuide_ENUS.pdf) on the Microsoft Download center here. The steps are under "Install Management Reporter 2012 on Windows Server 2003". How can I get a list of the available parameters? Run the following to get a list of available parameters: MRDatabaseDeploy.exe /? Can you provide an example of the syntax needed to deploy a new Management Reporter database? Below is an example of the syntax to deploy a new ManagementReporter database to a remote machine named SQLServer MRDatabaseDeploy.exe /action:create /databasetype:ManagementReporter /servername:SQLServer /databasename:ManagementReporter /databasecollation:SQL_Latin1_General_CP1_CI_AS /databasemasterkey:pass@word1 /servicedomainuser:contoso\mr_svc /adminuser:contoso\ryan Note: This should be a single line of text with just spaces with parameters between each switch. I broke this into three lines to avoid the text being cut off. (Please visit the site to view this video) Источник: http://blogs.msdn.com/b/dynamicscpm/...dows-2003.aspx
