Старый 23.08.2012, 19:11   #1
workflowax: Setup User workflow email notifications in AX2012
Источник: http://workflowax.wordpress.com/2012...ion-in-ax2012/
In order for users to be notified of new work-items that have been assigned to them you will need to ensure that they have their notification settings enabled. To do this you can follow the following procedure.
  • Navigate to the user options screen.
    • If this is for yourself, you can locate user options from the File -> Tools -> Options menu.
    • If this is for other users you can access the form via System Administration -> Common -> Users -> Select the correct user -> Click options on the toolbar
  • Select the notifications tab
  • Check the “Send notifications in email” checkbox. By default this is disabled.
N.B. Please ensure that you your email templates and outgoing mail server have also been configured and in AX.
workflowax: Organisation-wide Workflow Email Templates Blog bot DAX Blogs 0 22.08.2012 21:11
workflowax: Approve Workflow Items Via Email Blog bot DAX Blogs 0 07.05.2012 11:11
workflowax: Workflow history error – Stopped (error): Could not find user Blog bot DAX Blogs 0 11.02.2012 01:11
workflowax: What is a workflow owner used for? Blog bot DAX Blogs 0 01.06.2010 15:05
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 00:36.
