Старый 27.07.2012, 16:11   #1
emeadaxsupport: Content news: July
Источник: http://blogs.msdn.com/b/axsupport/ar...news-july.aspx
Hi everyone,
The Dynamics AX content publishing team has posted new and updated content for Microsoft Dynamics AX to TechNet and MSDN.
The following table contains links to each group of topics that we have added to or updated since June.
Audience
Approximate number of topics published
White Papers and Guides
6
System Administrator topics
5
Developer topics
15
Topics published on both MSDN and TechNet
(Analytics and Services)
3
For more information about our documentation see the following resources:
Help and Resources Datasheet for Microsoft Dynamics AX 2012
Official Dynamics AX 2012 Content
The following white papers and guides have been published or updated.
Enterprise Portal Development Cookbook
AX 2012 System Requirements
SEPA (ISO 20022 XML) credit transfer payments
SEPA (ISO 20022 XML) direct debit payments
Country-specific update guides
Management Reporter 2012 localized chm files
Local functionality for France in Microsoft Dynamics AX 2012
The following topics have been published or updated on TechNet.
Architecture and planning / Plan an implementation /
Plan hardware and software infrastructure
Considerations for global deployment
Models, Layers, and the Model Store
Troubleshooting working with model files
Resources for Microsoft Dynamics AX 2012 /
Microsoft Dynamics InformationSource
Combine XPO Tool User Guide
Data Migration Framework User Guide
Intelligent Data Management Framework for Microsoft Dynamics AX
Developer topics
The following topics have been published or updated on MSDN.
Help System Development /
Writing Documentation for the Help System
Authoring Help Documents
Microsoft Dynamics AX 2012 for Developers
Database for Microsoft Dynamics AX
Microsoft Dynamics AX 2012 for Developers /
Best Practices for Microsoft Dynamics AX Development
Frameworks Introduction
List of Error and Warning Messages
How to: Create Queries by Using X++
How to: Create Tables
How to: Update Data
Using Expressions in Query Ranges
Walkthrough: Creating a Valid Time State Table
Integration with Microsoft Dynamics AX
How to: Marshal Between X++ and CLR Primitive Types
Walkthrough: Integrate an Application with Microsoft Dynamics AX Using .NET Business Connector
Microsoft Dynamics AX IDE
AOT Overview
X++ Language Programming Guide
Local Functions
Method Access Control
X++ Keywords
Topics on both TechNet and MSDN
The following topics have been published or updated on both TechNet and MSDN.
Analytics
How to: Specify Dimensions and Attributes for a Cube
Services and Application Integration Framework (AIF)
Configure value substitution maps
Sequential and parallel processing in services and AIF
Старый 28.07.2012, 00:23   #2
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,343 / 3563 (125) ++++++++++
Зарегистрировал багу при преобразовании ссылок при импорте блогов.
emeadaxsupport: Content news: June Blog bot DAX Blogs 0 29.06.2012 13:11
emeadaxsupport: Content news: May Blog bot DAX Blogs 0 01.06.2012 01:11
emeadaxsupport: New Content for Microsoft Dynamics AX 2012 : November 2011 Blog bot DAX Blogs 1 05.12.2011 20:30
Мелкомягкий CRM: Панель управления для MS CRM с помощью Reporting Services Blog bot Dynamics CRM: Blogs 1 24.08.2009 14:41
Часовой пояс GMT +3, время: 14:41.
