Старый 13.07.2012, 16:11   #1
ax-erp: X++ code to find the Stock of Item by Date
Источник: http://microsoft-dynamics-ax-erp.blo...m-by-date.html
static void findOnHand_ByDate(Args _args)
InventDim inventDim;
InventDimParm inventDimParm;
Itemid itemid;
InventOnHand inventOnHand = new InventOnHand();
InventSumDateDim inventSumDateDim;
TransDate transDate;
// take a sample item for testing
itemid = "20 MM RMC";
transDate = 13\01\2010;
// take a combination of dimension , against which you want to find the stock
inventDim.InventLocationId = "GW";
//Set the flag for the selected dimensions as active.
inventDimParm.initFromInventDim(inventDim);
//initialize the inventSumDateDim with Date,item,dimension and dim paramter
inventSumDateDim = InventSumDateDim::newParameters(transDate,
itemid,
inventDim,
inventDimParm);
// Retrieve the onhand info
info(strfmt("PostedQty: %1",inventSumDateDim.postedQty()));
info(strfmt("DeductedQty: %1",inventSumDateDim.deductedQty()));
info(strfmt("ReceivedQty: %1",inventSumDateDim.receivedQty()));
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Вопрос про Demand Planner slava09 DAX: Функционал 4 25.09.2006 11:43
Часовой пояс GMT +3, время: 07:10.
