Старый 13.06.2012, 22:11   #1
ax-erp: SysQueryRangeUtil class - use method name as query criteria
Источник: http://microsoft-dynamics-ax-erp.blo...thod-name.html
This is a cool new feature in AX 2009 - you can now use a method name instead of literal value in query criteria!
For example, if you run a report every month, previously you need to change the date criteria in each month you running the report (ie. “01/06/2010..30/06/2010”, “01/07/2010..31/07/2010”, etc).
Now you only need to enter
(monthRange(0, 0))
which will automatic return the correct first day and last day of the month.
Refer to the SysQueryRangeUtil class – there are other useful methods such as dateRange(), currentEmployeeId(), etc. It’s also possible to create new method on this class for special purpose!
semanticax: Dynamics AX 2009 Installation - Application Blog bot DAX Blogs 0 22.12.2010 08:11
The TEC Blog: Microsoft Dynamics AX: The Chosen One Among Microsoft Dynamics ERP Equals? – Part 3 Blog bot DAX Blogs 3 20.10.2010 12:31
paruvella: Dynamics Ax - Simple SSRS report example by using Ax-Query and Ranges Blog bot DAX Blogs 0 08.01.2010 16:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
Dynamics AX: Sunrise Technologies, an ERP Reseller, Demos Microsoft Dynamics AX at ERP Vendor Shootout Blog bot DAX Blogs 0 17.10.2008 04:17
Часовой пояс GMT +3, время: 14:14.
