Старый 24.05.2012, 07:14   #1
emeadaxsupport: How to edit the master page of Enterprise Portal for Microsoft AX 2009 when using SharePoint 2010
Источник: http://blogs.msdn.com/b/axsupport/ar...oint-2010.aspx
Dynamics AX 2009 Enterprise Portal was designed with templates compatible with SharePoint 2007, and they are in this compatible mode in SharePoint 2010. Hence not all features are compatible for example with SharePoint Designer. Hence you are unable to edit the master page using this tool. Even if you could edit the master page using the SharePoint Designer, every time you update Enterprise Portal, say using AXUPDATEPORTAL.EXE, it would override the default master page with the copy stored in the AOT.
So therefore to edit the master page do the following:
1. Go to: AOT\Web\Web Files\StaticsFiles\defaultax
2. Export defaultax object
3. Make a backup copy
4. Edit this defaultax object, which is the master page, in NotePad for example
5. Import the new modified master page back into the AOT
6. Run AXUPDATEPORTAL.EXE to deploy the edited master page
--author:Charlotte April Rowe
axforum blogs: Квест: Подружим Dynamics Ax 2009 Sp1 RU7 c SharePoint Foundation 2010 Blog bot DAX Blogs 4 16.10.2017 17:50
emeadaxsupport: Microsoft Dynamics AX 2012 Enterprise Portal: How to provider access for user to be able to only Personalize Page on SharePoint 2010 Blog bot DAX Blogs 0 13.12.2011 22:11
emeadaxsupport: Unable to deploy AX 2009 Enterprise Portal on SharePoint 2010 even after patching setup files with hotfix 2278963 Blog bot DAX Blogs 0 08.12.2010 03:14
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Часовой пояс GMT +3, время: 22:10.
