Старый 23.01.2012, 16:11   #1
sjakalax: The model store has been modified
Источник: http://sjakalax.blogspot.com/2012/01...-modified.html
hi folks,
I've been involved in creating build scritps for Ax2012 over the last few months and have encountered (and conquered) a number of ... well, let's cal them 'obstacles'.
One of them is the 'the model store had been modified' dialog that pops up the first time you start an Ax client after the model store was modified. It actually gives you some options (start checklists, compile and sync or just skip the whole affair).
But sometimes this happens: you don't manage to select any option. I mean: you can click an option, but it does not get selected. In fact: the (modal) dialog (including the OK/cancel/close buttons) does not react at all.
My workaround is to start the Ax client directly in a developer workspace (ax32.exe -development), where you get the same 'modelstore modified' dialog, but it does react when you click it.
Another option is to undo the installmode setting on the modelstore (axutil.exe set /noinstallmode) which prevents the modelstore modified dialog from popping up, and fire the compilation, CIL generation an synchronisation (or any option you whould have chosen) manually.
Don't know why this happens, I just hope I save someone some valuable time with this workaround.
bye!
mfp: AX 2012 Meta Model Blog bot DAX Blogs 17 09.09.2011 02:33
emeadaxsupport: Store Connect: error “Multiple-step operation generated errors” Blog bot DAX Blogs 0 18.08.2011 18:11
dynamics-ax: Kees Hertogh: The Benefits of a Model Driven Layered Architecture Blog bot DAX Blogs 0 30.03.2011 01:14
dynamicsaxtraining: Setup initial data (Vendor, Warehouse, Equipment) Blog bot DAX Blogs 0 07.12.2009 19:05
Microsoft Dynamics CRM Team Blog: The Microsoft Dynamics CRM Plug-in Model and You Blog bot Dynamics CRM: Blogs 0 09.05.2009 06:40
Часовой пояс GMT +3, время: 02:55.
