emeadaxsupport: COGS value on Sales Cube shows not correct value
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ect-value.aspx
============== We run lately in the issue when COGS value is not correct calculated for Sales Cube. The problem occurs, when in Microsoft Dynamics AX are some return deliveries. For example 1 article will be returned as a negative position with a negative amount. The COGS field turns the negative amount into a positive (-4.000 $ -> +4.000 $). That problem is in named query CustInvoiceTrans where we have following statement: (SELECT ABS(SUM(COSTAMOUNTPOSTED)+SUM(COSTAMOUNTADJUSTMENT)) AS COGS The correct statement should look in following way: (SELECT -(SUM(COSTAMOUNTPOSTED)+SUM(COSTAMOUNTADJUSTMENT)) AS COGS ![]() --author: Damien Maspero --editor: Czesława Langowska --date: 7/July/2011 Источник: http://blogs.msdn.com/b/emeadaxsuppo...ect-value.aspx
Опции просмотра | |
