Старый 13.08.2010, 21:06   #1
sumitax: Use of ViewState in User control
Источник: http://sumitax.wordpress.com/2010/07...-user-control/
During development of user controls in EP, if  you wish to preserve the state(value) of  Page Level variables , you can use ViewState available in EP Framework in Ax2009. This is useful because Enterprise portal by default is stateless and if data  need to persisted across various postbacks events  in web control for example in a Dataset, ViewState comes as a handy option.
Scenario :  When a button is clicked on user control or user goes to next page in a Web control which uses a wizard , then a postback event is fired and value of page level variables is lost.
Usage : Use the following code to store the variable under ViewState
 ViewState[“InvoiceId”] = invoiceId;
And to retrieve the value , use code below
invoiceId = ViewState[“InvoiceId”]
sumitax: Calling external applications from User control in EP Blog bot DAX Blogs 0 13.08.2010 21:06
emeadaxsupport: Dynamics User Control is shown as hidden in Dynamics Ax 2009 Enterprise Portal Blog bot DAX Blogs 0 13.05.2010 01:05
Solutions Monkey: 64bit machine - VS EP add-in not deploying user control to SharePoint while saving Blog bot DAX Blogs 0 06.01.2010 08:19
Solutions Monkey: Redirecting in EP user control to download a file Blog bot DAX Blogs 0 11.09.2009 15:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 02:42.
