Старый 06.08.2010, 17:05   #1
Pawan's Ax blog: How To Cache A object Globally in Ax
Источник: http://pawansaxblog.blogspot.com/201...lly-in-ax.html
There are three way to cache objects.
A global cache is an instance of class - SysGlobalCache, which is nothing but a Map containing Maps with a Key. These Maps contain the actual value and a key.
In Ax, we have three Global Cache Classes
1.Infolog.globalCache()
2.Appl.globalCache()
3. ClassFactory.GlobalCache().
How to use:
static void GlobalCacheSetAndGet(Args _args)
       SysGlobalCache globalCache;
       class          test;
      globalCache = infolog.globalCache();
     if (globalCache.isSet(classstr(test), 0))
        test= globalCache.get(classstr(Test), 0);
        return test;
    else
        test= new test();
        globalCache.set(classstr(Test), 0, test);
        return test;
Pawan's Ax blog: HOW To Do Debugging In AIF Blog bot DAX Blogs 0 01.07.2010 22:07
Pawan's Ax blog: How To Restore Data In AIFSchemaStore Table Blog bot DAX Blogs 0 01.07.2010 22:07
Pawan's Ax blog: How To Delete All Transaction Data In Ax Blog bot DAX Blogs 4 15.06.2010 11:23
Pawan's Ax blog: How to run AIF job Blog bot DAX Blogs 0 19.04.2010 11:05
Часовой пояс GMT +3, время: 19:48.
