Старый 22.07.2010, 19:06   #1
paruvella: Insert the De-Serialized XML file values into Ax-Table
Источник: http://paruvella.spaces.live.com/Blo...4DB0!549.entry
Further journeying from my previous article
http://paruvella.spaces.live.com/blog/cns!F2EC589E221A4DB0!546.entry
In my previous article we have explored how we can read the XML string and field values.
In this article we will explore, how we can store those field values in to the table.
Assume that we have table,
Now generate Ax-BC class for the above table, if we already have Ax-BC for the same no issues, otherwise create the same from
AOT à Classes à AxGenerateAxBCClass
Run the above class by selecting our above table.
Make sure that class is free from compile errors.
After the Ax-BC class is created and made that compile free. Use the following job.
static void PSReadXMLFileAsStringAttr(Args _args)
    XmlTextReader       xmlTextReader ;
    str                 xmlString = 'http://www.w3.org/2001/XMLSchema-instance">'
                                    +'o130006'
                                    +'260005'
    str                 fieldName;
    SysDictClass        sysDictClass;
    str                 parmMethodName;
    AxATGAXSTGCustTable axCustTable;
    xmlTextReader = XmlTextReader::newXml(xmlString, true) ;
    while(xmlTextReader.read())
        switch (xmlTextReader.NodeType())
                case XmlNodeType::Element: // The node is an element.
                    fieldName = xmlTextReader.Name();
                    switch (fieldName)
                        case "ATGAXSTGCustTable":
                            sysDictClass = new SysDictClass(classnum(AxATGAXSTGCustTable));
                            axCustTable = sysDictClass.makeObject();
                            break;
                    break;
                case XmlNodeType::Text: //Display the text in each element.
                    parmMethodName = "parm" + fieldName;
                    sysDictClass.callObject(parmMethodName, axCustTable, xmlTextReader.Value());
                    break;
                case XmlNodeType::EndElement: //Display the end of the element.
                    switch (xmlTextReader.Name())
                            sysDictClass.callObject("doSave", axCustTable);
                            break;
                    break;
     pause;
Run the above job and see the result in table from the table browser.
paruvella: De-serialization of string format XML in Dynamics Ax Blog bot DAX Blogs 0 21.07.2010 22:06
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
paruvella: Generation of XML file from DAX, without using AIF Blog bot DAX Blogs 0 23.04.2010 12:05
Axapta Lessons: Export a table to a file Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 05:37.
